Results 1 to 10 of 11
    Feb 2014
    North Bay, ON
    Default 2005 XC Reduced Engine Performance
    Hi all,
    Can anyone give me some diagnostic tips on how to determine the cause for my reduced engine performance light coming on?
    Info: I had just warmed up the car for a few minutes, driven about 300m and while accelerating from a light, power cut out with a message saying reduced engine performance. I pulled over, turned the car off and back on - no longer a problem. It hasn't been long since that happened, and it hasn't happened more than once.
    What should I do to investigate? Thanks!
    Travis
    2005 Volvo XC
    2005 Volvo XC70
    Feb 2014
    North Bay, ON
    Could it have something to do with the MAF sensor? How reliable are those on the 2005 year? The ETM seems to be reliable as compared to the early 2000 editions, so I'm looking in other directions. The problem hasn't happened again, and I'm not worried about if it happens again while I'm driving - I just worry about my wife. I'd rather get it solved before another 'attack' so that she doesn't have to be nervous about driving the car anywhere.
    2005 Volvo XC70
    There are several possibilities. MAF is one of them. Cleaning it might help. It might not. Sometimes, MAFs go bad...
    Guessing isn't really a good method of troubleshooting. Get the codes read, preferably by a VIDA/DiCe machine and someone who knows Volvos.
    If this car is new to you, then baseline it. Change fluids, filters (oil, air, fuel) and spark plugs.
    Feb 2008
    Franklin NC, Towns Co. GA
    Amen.
    Throwing lots of parts at a problem will bankrupt you, and not help the car...I know.
    It is possible that even a cheap code reader or the "free read" at neighborhood auto parts store might tell you the problem.
    But it might take VIDA/DiCe...
    Could be any one of a plethora or items: a cracked vacuum hose, fouled PCV system, an intermittently failing coil, fouled plug, bad gas, stopped up fuel filter, one of many sundry sensors failing, plugged injector, etc., etc...
    *2005 Ice White XC70
    444K miles and...well...
    Driving the 08 V70 right now.
    "Ah! There is nothing like the smell of burning British electrical components in the morning!"
    Feb 2014
    North Bay, ON
    Quote Originally Posted by TheDarkKnightt View Post
    Amen.
    Would a MAF removal/cleaning and reinstall be a bad thing to do? The cans of MAF cleaner are about 10 bucks - I will likely get it read later this week regardless, but should I go ahead with the cleaning?
    2005 Volvo XC70
    Feb 2014
    North Bay, ON
    The reduced engine performance message came on again this morning - right after start up while idling. I turned off the car and restarted, it went away. Drives with no problems. I cleaned the MAF this afternoon - hopefully that was enough, if it happens one more time its Vida/dice time. There are no stored messages in the message centre, and no continual warning lights.
    2005 Volvo XC70
    Dec 2013
    Ontario, Canada
    Quote Originally Posted by tmurph05 View Post
    Is your check engine light on? Looks like you don't have many options in North Bay but a quick search shows that Parolin Euro Auto should have the right equipment to read any stored codes and this is essential, given your problem. A generic code reader won't help. Good luck.
    Feb 2014
    North Bay, ON
    Quote Originally Posted by pmortxc70 View Post
    No check engine light. I have a guy at ABC Auto Center who knows quite a bit about european imports (and is a little cheaper than Parolin's) who will likely read it for me later this week.
    2005 Volvo XC70
    Unless they have VIDA they can't read any stored codes
    Quebec
    Right.
    Had similar symptoms, but with rough start (long cranking). It was the RPM/crankshaft sensor.
