I just bought this 2006 XC70 to fix for as a new-2-me daily driver and thought I would share with forum from the previous owners records as insight into PCV maintenance as some posts suggest you can inspect/clean the PCV while others suggest to replace. Personally, I like replace... but I think the dealer invoices also documents other areas of the motor to inspect when servicing your PCV.
The following is the cars services history:
Mileage: 30K, 60K Service Performed by Dealer w/ 7.5K intervals performed either by dealer or Jiffy Lube
Mileage: 93.8K Service performed by Dealer 90K service ($1K) - portion specific to PCV: NOTED AT SERVICE PCV HOSE SPLIT, LEAKING
Fix: OPCODE EI72 Crankcase Ventilation, Inspect / Clean (in conjunction with service)
OPCODE 93814 REPLACED BROKEN BREATHER BOX HOSE (BREATHER BOX TO CAM COVER)
Mileage: 94K - 110K Oil Changes performed at intervals by Jiffy Lube
Mileage: 110.3K Diagnosis performed by Dealer Per Invoice: CUSTOMER STATES LOW OIL LIGHT CAME ON, CUSTOMER HAD OIL CHANGED. THEN WHILE DRIVING CHECK ENGINE LIGHT CAME ON AND TAILPIPE STARTED SMOKING, BLUE SMOKE COMING OUT EXHAUST
OPCODE 110388 TURBOCHARGER DAMAGED. POSSIBLE INTERNAL ENGINE DAMAGE FROM RUNNING VEHICLE WITHOUT OIL. OIL LEVEL CURRENTLY OK AT TIME OF CHECK OUT. OUR RECORDS INDICATE LAST OIL CHANGE PERFORMED AT THIS FACILITY WAS OVER 16,500 MILES AGO. SEVERE SMOKE COMING OUT OF EXHAUST. PCV SYSTEM NOT WORKING OR UNABLE TO KEEP UP WITH CRANK CASE PRESSURE. INSPECTED VEHICLE. FOUND OIL LEAKING BETWEEN TURBO CHARGER AND CATALYTIC CONVERTER FLANGE. ALSO NOTED LIQUID OIL LEAKING FROM MID SECTION OF EXHAUST PARTING FLANGE AND OUT OF TAIL PIPE. REMOVED TURBO DRAIN TUBE, CAN SEE SIGNS OF OIL SLUDGE IN TURBO. DRAIN PIPE IS FREE OF DEBRIS. TURBO IS DAMAGED. OIL LEAKING FROM TURBO HAS ALSO LIKELY DAMAGED CATALYTIC CONVERTER AND BOTH OXYGEN SENSORS. NEED TO REMOVE OIL PAIN AND INSPECT CONNECTING ROD BEARINGS AND FOR SIGNS OF SLUDGE IN PICK UP TUBE, BOTTOM OF OIL PAN, AND CRANK CASE VENTILATION PASSAGES IN BLOCK. RECOMMEND COMPRESSION AND LEAK DOWN TEST TO TRY AND DETERMINE OVERALL HEALTH OF ENGINE
ESTIMATE: CATALYTIC CONVERTER, O2 SENSORS, & TURBO CHARGER $4,700.93
PCV SYSTEM AND BOX $1,100.57
MAY NEED FURTHER ENGINE REPAIRS $?,???
I will keep the forum posted on my progress on this one... could be a while... good thing my 01 & 04 still run like champs (with replaced PCV's)
