Hii Folks,
Had a poor running condition that came out of nowhere and no DTC trouble codes found.
[Went to start the car again after having been run and warmed up],Would run [Missing badly]but wouldn't rev past about 2000 rpm, [and had to idle back into home base].
Removed and re-installed the Main relay-(engine system) #9162300.
Car ran perfectly the rest of the day. . .
[Same thing happened a day later (today) and at the same location]
Made an inquiry to IPD and got this response:
Have ordered a new relay as the same condition cropped up again today.Originally Posted by Brandon Weaver
So a search on ECU- Re learning came up with 2 scenarios:
1. is to touch the battery cables together. . .
2. is to re-learn the ECU by disconnecting the negative cable only and tap the brake s a few times.
Reconnect cable with key in position II, to avoid problem with triggering an SRS fault.
Should I just replace the new relay dead-nuts or follow a particular procedure before doing so?
[or should I try an ECU Clearing with the existing relay]
Unemployed and can't afford a Dealer visit.
Comments appreciated- car has about 140,000 miles.
Thanks in Advance any and all help. . .
Brien
