Ladies and Gents,
I seek any advice or thoughts you may have on a problem with my XC.
I own a 2005 XC70 purchased new and meticulously maintained. 80,000 miles, all factory reccd service done under waranty and after waranty, done by me. I run synthetic and really try to take care of the car.
About 2-3 months ago my wife and mother were driving the car at road speed and experienced a loss of power and hesitating. It occurred again about a week later for my mother and father in the car and this time resulted in a loss of power, hesitating, and finally a stall when reaching a traffic light. The first occurrence was after the car was warm, about 20 minutes into a drive. The second instance was just after start on a somewhat colder day.
Since these two occurrences, I have had it happen to me while driving. One of the times it occurred twice after the car was warmed up and at driving speed. The car started to lose power, RPMs dropped, I feathered the accelerator to try and keep it running, and after stopping the foot action it stalled on the side of the road. Turned the ignition all the way off, restarted, continued on and it happened a second time. Same symptoms. I did the same actions, and drove it to the destination with a few more momentary blips of problem. Shut it off. Drove it home a few hours later with no issues.
In addition to the engine related issue, I have also had the Starter Immobilizer issue "Start Prohibited Try Again". Usually clears by turning ignition off and back on again.
Here is what I have done so far and the results:
I had my Volvo Mechanic pull the error codes off the car and he came up with ECM710B Immobilizer Comm Missing, ECM291D Fuel Pump Control Module signal too low, ECM291B Fuel Pump Control Module Signal Missing, CEM9C03 antenna light ring signal missing, CEM6c49 Transponder comm faulty signal, CEM6c48 transponder type faulty signal.
I took the car to my local Volvo dealer and had the complimentary software updates done on the car. Volvo tech journal references a software bug for causing the start immobilizer problem. I also hoped the software would fix the power loss and stalling problem.
After the software flash both problems resurfaced. The Start Immobilizer issue would come up after sitting in a parking lot with the ignition in position one listening to the radio and then going right into a start-up from that position. I would turn the key all the way off and start normally on the second try.
The power loss continued to occur at random intervals. Sometimes the car seemed to idle rough, sometimes it would almost "miss/stall" for a momentary second while driving.
After talking with the Volvo dealer mechanic who performed the software update, I decided to replace the Fuel Pump Control Module (PEM) per the Volvo 23-32 4/30/2008 Service Bulletin which replaces the module underneath the car with a new one located near the spare tire in the rear compartment as I felt this was likely the culprit of the problem. His advice right after doing the software flash was to see if the new software fixes the issue, and if not, consider doing the control module for the fuel pump. The original factory part was mounted underneath the car and exposed to moisture, temperatures, etc. It was a straight forward job and I had no problems completing it.
Last night I drove the car after making the PEM replacement and for the outbound trip, it ran flawlessly. Coming back, the same hesitating, power loss, momentary "missing" happened again. (Back to the drawing board!) My father and I own two Volvo XCs, his a 2006. We discussed the problem and researched more this morning and read a bunch on all of the Electronic Throttle Module issues with the early 2000 Volvos. I had asked the dealer about this during my visit, but he told me, in his experience, my model year did not suffer from these problems. Still, after reading a bunch of kindly published information, I had a hunch that the ETM or Mass Air Flow Meter MAF was a likely culprit. Neither of these seem to throw off or generate error codes either!
To trouble shoot the MAF, we switched MAFs between our cars this morning (same identical part) and went out for a two ship test drive. Sadly I was still able to duplicate my power problems by coasting for a bit and then coming hard on to the accelerator. The car would momentarily jerk or lose power during the acceleration. It was also idling rough which was noticeable on the RPM gauge and by listening to the muffler.
Next, I went ahead a garaged the car and took off the ETM and cleaned it thoroughly with carb cleaner and a tooth brush. I had read about dealers performing this work as a potential fix. Most of the authors seemed pretty skeptical.... After the replacement of the cleaned ETM (which was dirty), the car is still idling a bit rough. It has not had the loss of power, stalling , or other symptoms yet, but realistically, I am waiting for it to happen. I am skeptical that the cleaning fixed the problem.
The only other data I can provide is that as part of the recent factory rccd maintenance work I did replace the plugs. I did not replace the plug wires, fuel filter, vac hoses, etc. as they "appeared" to be in good shape.
I am starting to be at a loss as to the cause of my loss of power issues. I am obviously hesitant to outright replace the ETM due to the cost. (It also burns me up that I can easily do the install myself but the dealer has to flash the software....)
Do you feel it could be related to the start inhibit, immobilizer problem? Could a lose antenna ring cause ignition cancel signals to be generated? the immobilizer issues never "shows" itself while the loss of power problem is occuring?
I have thought of vacuum leaks but felt those might be present full time, or at least every time a hard power input is made?
What would you do at this point? What other ideas do you have to check, perform, do?
Many thanks.
