Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Quote Originally Posted by kamiar View Post
    I am on 150,000KM and had replaced 2 WP due to leaks!!!!
    Yeah...have to say, that is odd...my 850 had its original pump at 185K...and both my current cars have the OE pump...but I've been very careful to use only the Volvo BG coolant...figuring that it has worked well pump longevity and saving $10 on coolant is not worth having to change that pump...did you stick with the Volvo coolant? Just curious...
    Oct 2009
    Manassas VA
    160k miles. Replaced the timing belt at 110k miles but not the pump. no issues to report.
    knock on wood.
    Jan 2011
    Volvo never had a service interval listed for the WP on white engines.
    The diesels used a water pump you moved to tension t belt and you had to remove pump to replace seal when you did belts as cleaning block face was always needed. The seal was about 1/2 the price of pump and we often saw pumps fail before the second belt interval. So WP's always got changed on those.
    Due to short life WP on so many engines with t belt driven pumps the practice became widespread even on engines with very long WP life.
    Sep 2008
    Montreal, Canada
    Yes i always used the Volvo coolant, but the first WP that i put was not a Volvo part, so now the car is on 3rd one (including the one came from factory)
    Mar 2011
    modena italy
    Last week my Volvo delear change in my XC70 D5 ( DIESEL ) all the belt and all the timing kit includeed water pump. In Italy all Volvo delear include water pump because is very important and is cheap too.
    630 euros for timing belt kit all included.
    Regretting :
    Oct 2010
    Ottawa, ON, Canada
    I did the water pump on mine, even though it would likely be ok. The cost of the pump is less then the cost of the labor/hassel to redo it if it goes bad before the next t-belt change.
    I also got the car second hand, so did not have a full service history on it, which also played a role in my choice.
