Rotors are available (I had them but removed them for noise on my wife's 2000 V70R).
She did not use them hard enough.
Oh, they'll be used more than hard enough... no problem there. Maybe the Big Brake Kit will help over the 280mm Zimmermans... which are so far pretty good, but we'll see after a week or two of doing the 'Plummet From the Summit'.
This is what you need to do to stop the low speed rumbling that comes after a few thousand miles with them.
If hard use is required to keep the rumble away, that's fine... my only worry is how much braking power and fade resistance I can get.
Sure, the brakes are great but are you sure you want to spend all this money on a 98 XC?
Yeah. It's my favorite year and model of AWD, for my needs the best, too. Despite its relatively primitive AWD system and roly-poly suspension... with the cable throttle, old-skool ignition system, LPT power/torque delivery and reliable 4-speed automatic, I'll stick with her... hit a 200+ lb. deer doing almost 70 mph on the highway outside of Wilkes-Barre last summer and it barely got my nine-year old son to look up from his book in the back seat... pulled over after we'd punted the hooved vermin back over the guard rail, pulled the front right quarter panel away from the Nokian and just kept on going all the way back to NorCal with a beat-up hood, quarter panel and no A/C, which gave its life to save the radiator... despite one headlight getting crunched, both headlights worked until we got it all un-deered at a good body shop this fall... no frame damage and 29 mpg with a full load at 70 the rest of the 3500 miles... I know any XC could do that, I guess, but she saved our lives, no doubt. Since it's already my favorite year and model and I need the ground clearance more than I need the R on the rear hatch or a high-beltline 2001+ XC that looks like a Ford Taurus from the dash back, we'll keep her... so yeah, I'm sure.
You need a pair of these mounted somewhere on the front!
