Results 1 to 6 of 6
    Nov 2011
    Minnesota
    Default Check Engine Light - Question
    My CEL came on, But it went off after about 12 hours. So my question is the CEL does not stay on till the code is cleared? Does it turn itself off due to time or mileage.
    May 2011
    Quebec
    It could be a intermittent code which is still stored even if the CEL disappeared. Get the codes read to give you a idea why.
    2000 Silver V70 XC SE - 153,000 miles and counting...
    Mostly stock - IPD HD TCV - IPD HD coils
    Aug 2007
    NJ
    Abad ignition coil will do that sometimes. Show a fault and then dissapear. Like said previously have the code read and see if there is a stored one....
    2017 Maserati Ghibli - Blu Emozione, Black Leather 17k miles
    2013 Subaru Outback - charcoal Grey, Eyesight Collision Avoidance 110k miles
    2007 XC70, Barents Blue, Charcoal Leather 200k miles
    2001 Honda Accord V6 SE - 82k miles - Steady reliable transport
    It will be stored in the computer
    Sometimes a gas cap code will go off after the cap has been re-secured
    (not always but I have seen this happen).
    Also a quick misfire for whatever reason can cause a code but will go away if it was a quick misfire and for whatever reason the car is now running nominally again
    (Stored code has to be read by Volvo, a small scanner will not show it)
    Nov 2011
    Minnesota
    So my Equus 3140 Innova scanner will not read stored codes?
    Dang!
    Not if it's not showing, then it would be stored in the system
    Only VIDA can read a STORED code
