I'm in the middle of changing out the PCV system on my (`98 V70xc AMT), and will replace the Oil Cooling lines, Radiator Hoses, seals on the Trans lines, etc.... I got the O'rings and hardware for all the lines to the radiator, but when I removed the lower Trans Oil return hose from the Radiator, the metal elbow that goes into the crimp fitting on the hose appears to rotate in the crimp fitting, quite easily. I do not see any major leaks around this area - so I was wondering if this was normal?
If not normal, is there a good place to get a replacement? (FCP and IPD did not seem to list the Trans Cooler lines for ordering.....Drivewire, Partsgeek - show them available - or dealership?)
