Results 1 to 8 of 8
    Nov 2011
    Clearwater Beach, FL
    Default Help! Replaced Battery..now Steering,Headlight,Radio ETC Please Help!!
    So I went to the local Autozone, purchased a battery and hooked up the memory saver thru the OBD II connector. Swaped the battery jumped in fired it up and suprise......door locks, sunroof, maplights not working...ok ouick fix lock and unlock with master key and bang I'm in business. Now i drive away and flip on the turn signal...not working (hazards are working) so i pull over and start searching for other issues and find that none of the steering controls work. Radio works but is dim (cant see anything) Headlights work but switch does nothing and Fog lights are out. I have now disconnected the battery for thirty minutes and tried the neg and pos touched together for 30 sec. NOTHING Works HELP Please.
    Thank you in advance for any response replies.
    Cyrus
    PS. Alarm service requried light is on but has been before this.
    You're not going to like the answer...you did it wrong...there are notes here...
    Follow them, and with luck, you'll reboot the UEM and those things will start working again...
    2001 V70-T5 (92K)
    Nov 2011
    Where are the notes to follow?
    Thanks for the quick response.
    Cyrus
    Nov 2011
    Default Uem
    Map Lights, Doors, and sunroof work. But the rest still not working. any advice to reboot Steering control Module?
    The pdf contains the disconnect/connect procedure.
    Willy
    Nov 2011
    Default Thanks Willy
    Followed these instructions... still have same issues.
    Nov 2011
    Default Smacked the fuse box and all is well again!
    Must have been loose????? IDK!!
    That must have been an intuitive action
    Willy
