Drive this thing with no oil pressure and you frag the engine and turbo.
Two reasons the light comes on: 1. you have no oil pressure. 2. the pressure sensor (sender) failed.
No/low oil pressure will happen if you a: run it low on oil (pump sucks air from the sump) or b: the pick-up screen is plugged up with sludge/carbon or c: the oil pump itself failed or d: the engine bearings are so worn that the pump can't maintain pressure.
First, check the level on the dipstick - you may simply be out of oil (do you check it at every fill-up like you should?)...if no oil on the dipstick, fill to the right level, start the engine and see if the light/warning goes out.
If the level was good, have it towed (don't run the engine with no pressure!). and have a mechanic check the oil pressure with a known good gauge. The sender is easy to find on this engine.
If you're lucky, he will find good pressure with his gauge because it's the sender. If not, the oil pan comes off and you have to check/replace the pick-up and pump. If it was operated for more than a few seconds with that message on because the pressure was actually low, then you may be looking at a new engine anyway...
2005 MB S600 (121K, Michelin AS3+, High Performance Lubricants 0W40)
2004 V70R (142K, six speed M66, High Performance Lubricants 5W40)
2002 V70-XC (292K,High Performance Lubricants 0W30 Euro)
