Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
  1. #31
    Jul 2008
    NC
    Thanks for following up with the solution to the problem!
    2000 V70 XC SE
    165,000 miles and runs great.
    Total repair costs over last 65 months: $720 (about 1.5 car payments);
    Best single tank mileage ever: 32.8; Average mileage: 22.2; City: 18
  2. #32
    Aug 2007
    NJ
    Default Part # - Bushing
    YLStaffer....can you provide the part # on that bushing you replaced. The volvo Dealer has no idea what i am talking about. If I could get it by tomorrow it would be a huge help as i need to order the part and install it before I go to Vermont on Thursday!!!
    I have a new propshaft coming and I don't want to find out it was just the bushing and was an easy fix. Sounds like a good idea to replace the bushing anyway While I am under there I doing the propshaft....
    Thanks for the help!
  3. #33
    Jul 2009
    Ithaca NY
    Unfortunately I do not have that part number 8pack, sorry! I'm a little disturbed that your Volvo dealer service rep didn't know about it. My service guy tells me that it's not uncommon. I'll look around online and see if I can at least find the proper name for it.
  4. #34
    Jul 2009
    Ithaca NY
    I just called down to my indie shop and he had the PN right there handy... 9143894... hope this helps!
  5. #35
    Aug 2007
    NJ
    Thanks! Will call and order and let you know how it goes!
  6. #36
    The bushing is PART OF the propshaft
    You do not want to buy one if you're installing a new shaft
  7. #37
    Jul 2009
    Ithaca NY
    No JRL this bushing is the one that is located on the arm of the VC housing where it mounts on the body above the axle. It has nothing to do with the prop shaft.
  8. #38
    I thought you meant the front prop U joint, my bad
  9. #39
    Aug 2005
    SL UT
    Quote Originally Posted by ylstaffer View Post
    So I just got the XC back from the shop and sure enough, it was that sneaky little bushing where the VC housing mounts to the body. Sounds nice and quiet now (no more clunk). As for that 'rubbing' sound, I'll hafta get it out on the highway to hear that again. So my buddies at the shop replaced that bushing, put my prop shaft back in, (they had to come up with the 12 bolts, I couldn't find them ANYWHERE ) topped off all the fluids in the drive train and diagnosed another oil leak (oil cooler lines) for $150. Anywhere else would have been twice that or more. But in any event, case closed!
    I understand this is old thread but I am having the same clunking sound when I turn left at low speed or doing a U-turn. Interestingly, my driveshaft was just replaced with a brand new one 2 years ago when I complained of the same thing (only difference it was making the sound when I made a right turn).
    I'm aware it could be the viscous-coupler but I'm hoping it's the VC housing mount bushing. Can the bushing be replaced without removing the driveshaft and/or VC? Thanks!
    '00 V70R AWD
    '02 S40
    '13 XC60 T6
    '16 S60 T5 AWD
