Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Ontario,Canada
    Quote Originally Posted by Art View Post
    Keep in mind that the part # is different depending on the MY and chassis number of the vehicle as was explained in my previous post. The part number should be visible on the inside of the cover.
    Chassis # 104874 = Part # 9483518
    Chassis # 104875 = Part # 30753642
    Art,
    I was able to pick up a wiper motor free from a 2004. I also took the arm. Its the opposite side of what i have on my 03. Will it still work if if I use the 04 motor and 04 wiper are? Can you switch sides?
    Jim
  2. #22
    Art's Avatar
    Oct 2001
    Red Deer, AB., Canada
    Quote Originally Posted by jdp6000 View Post
    Art,
    Jim
    Jim,
    It appears that the same chassis rule also applies to the rear wiper motor as it does with the cover. That being said, I can't see why it wouldn't work on the opposite side if you have the applicable parts. The only issue might be that the configuration of the 04 wiper motor and mounting holes isn't an exact match to the original motor. I guess you'll discover that once the tailgate panel is removed.
    If it does works, it would likely be a first for this site.
  3. #23
    Ontario,Canada
    Jim,
    Thanks Art.
    When it gets a bit warmer up here I'll give it a shot.
    Jim
  4. #24
    Ontario,Canada
    So I fixed it.
    I took out a wiper motor out of a 2004. It was the opposite side. I took mine out then realized the knozzle was broke off of the 2004 motor. so I took my 2003 motor apart. To see if i could use that knozzle. when I got it apart I pulled out the white nylon gear to see what was up with it. I noticed that there was a ring of rust around the ring where the electonic tabs make contact. There was a pattern to it and it was obvious that this controlled the start and stop location of the wiper. I cleaned it, sanded the rust off and put it back together. It works perfect. See pictures below. Those rusty rings should not be there. So if anyone else has a problem with the wiper stopping where ever it wants whenyou trun the switch to off this is your fix.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  5. #25
    Ontario,Canada
    2004 Pump with broken knozzle. Anyone need one? It was working so if you can pull yours apart and replace the knozzle it should work. Wiper rests to the right with this one...
    [IMG][/IMG]
    [IMG][/IMG]
    See broken knozzle in this pic....this is the part that directs the washer fluid.
    [IMG][/IMG]
  6. #26
    Jul 2006
    MA
    Default Water in motor housing
    Hi, I just replaced a broken nozzle this weekend and decided to take the housing apart and noticed that there was about a teaspoon of water in there (no rust though). The nozzle broke about a month ago (probably while I was clearing off snow from the car) and I didn't get a chance to replace it until now so just be aware that rain water can get in and contaminate the contacts and possibly the motor with a broken nozzle that's left unrepaired.
  7. #27
    Apr 2012
    Michigan
    Default Thanks!
    I'd like to thank everyone that contributed to this thread! Thanks to everyone I was able to fix my rear sprayer without any hesitations or hiccups.
  8. #28
    Jun 2012
    Hartford
    I followed the steps in the tread and was able to fix both nozzle and cover on my 2005 XC70.
    Thank you for the help!
  9. #29
    Feb 2003
    Maryland, USA
    Thanks for these tips/instructions. I broke the rear washer nozzle on my '03 last week while trying to take the wiper arm off. Ordered replacement parts rom IPD. Nozzle was $8.58. Easy half-hour job to fix it. Thanks!
    Cheers, Gary
    2022 XC60 B5/Black
    2021 XC60 T5/ Osmium Gray (Wife's)
    2017 XC60 T6/ Bright Silver (Loaned to my Son)
    2015.5 XC70/Silver (Loaned to my Daughter)
    2007 XC70/Rubyred (RIP)
    2003 XC70/Platinum Green (RIP)
    2001 V70/White (RIP)
  10. #30
    Apr 2012
    Calgary
    Quote Originally Posted by Crazy Harry View Post
    It doesn't matter which way you turn it. The nozzle is pressed into a brass tube which is just friction fit into rubber or plastic, enough friction to prevent water leaks. Turning the nozzle will probably turn the tube as well which will just rotate in the rubber or plastic. There are no threads, so nothing will loosen or tighten when you turn it.
    Harold.
    What seemed like a big deal was literally a 10 second fix! - Thanks Harry and co.
    2006 VOR XC70 - #41/100
