what year drive shaft do you have, late 99 and 00 can't be separated but all 98 and early 99 can have the bearing replaced and I have both bearings and have sold many of them,
Hi:
Do you still have a carrier bearing for a 99 Volvo XC for sale please?
If so, I can do PayPal.
[email protected]
Many thanks.
I just uploaded all the info on volvo xc70 drive shafts to my blog, if you need new drive shaft for your 2000 volvo xc70 I have listed place where you can buy one
http://volvopartsearch.com/blog/
2002 c70 coupe 2.3T HPT, 2004 s80 2.5T, 2000 c70 convertible LPT
Ultimate volvo blog-find answer to your question
Arj -if your center bearing is shot, more than likely the CV joint on the front of the shaft is toast (literally) from being baked by the heat of the cat converter next to it. My center bearing was shot at about 208K and when I pulled the shaft also found the front CV joint in bad shape. Presently running without the shaft in full time FWD, will likely replace it with a reman one from Colorado Driveshaft. Think the last time I checked their Web site, they were asking less than $500 for the 98XC shaft assembly. Changing just the center bearing will likely be a waste of time and money unless you have access to a lift to do the labor yourself and want to gamble that the front CV joint will last much longer.
It's a total waste of time
Replace the entire propshaft
I think C/D is closer to $400 now even for retail customers
Thanks Stonington XC70
I like your interim solution of removing the rear shaft and driving FWD. But is there a differential function in the transmission that will make the rear shaft coupling spin with no load? ... And lose torque in the front?
Will check the full shaft options . Thanks
Huh?
Just remove the propshaft and drive the wagon. It then drives like any other FWD Volvo will drive.
