So today I take my 2000 V70XC to the dealer for them to replace under the used car warranty (30 days 1K) the driveshaft front coupler joint, goes off without a hitch. Pick up the car and driving home, a few miles from the dealer I go to stop and the dash light on the left side lights up everytime I hit the brakes, I know this is to let you know the brake light bulb is blown, does it three or four times, then It stops. I play dumb and go right back to dealer 5ms later. They look at and the brake lights are working fine as me and the Service Manager look on as the tech hits the brakes!!. The SM tells the tech to change the bulbs anyway maybe its a loose filament in the bulb, he does and they again work fine. SM says "no charge, now we know the brake bulbs are OK, if it happens again we may have to change the wiring harness in the tailgate" this sounds costly to me Im thinking or can I do it myself, and is this the problem? Anyone have this problem?? could it be a loose wire or when I wash it water gets in, because they washed the car for me, Im thinking this also happened once after I washed it! but i checked it then and the brake lights were working fine but the dash light lit up, and again this warning light went away. Now an hour later I get home and the light comes on again when I hit the brakes, again the brake lights are all working fine and the dash light went off again??? What gives thanks Bill
