Go Back   Volvo XC Forums > The Vehicles > 1997-2000 V70XC
Reply
Thread Tools Display Modes
  #1
Old 03-04-2009, 11:11 AM
paxc70 paxc70 is offline
Junior Member
Default Elimination or modification angle gear
Hello everyone. New member but long time Volvo fan.
I recently purchased a well maintained 99 XC70 that was dealer maintained and seemed to be an overall good purchase.
As the problem with many, my angle gear is now toast. I was leaving for work and back out of the driveway no problem. When I attempted to move forward, the car acted like to was in park. In a act of frustration, I floored the car and it moved, resulting in the angle gear case exploding and leaving two chunks of metal on the road. Total destruction!
A friend suggested disconnecting the six bolts from the rear drive shaft to the unit. The car now runs and drives but not well.
My question is does anyone know of a way to completely eliminate the angle gear? What year right drive shaft will work. What model.
Also I have a line on a used angle gear from a 2004 S60 R unit with low miles. Is this a possible replacement? I apologize for my ignorance but am really in a bind right now and need the car. It is very clean and besides this issue, is a gem. Any help will be great!
  #2
Old 03-04-2009, 12:58 PM
Junior Member
So after calling a Volvo nut I found out the dimensions on the later gear are different at a minimum. That idea is pretty much shot.
Now I figure my best chance is the elimination of the unit using 850/S70/V70 drive parts. The only issue I see is the input at the transmission, (axle seal, spline count, etc). I figured with all of the problems associated with this terribly designed part, someone would have attempted this at some point.
Any help would be terrific.
  #3
Old 03-04-2009, 01:58 PM
binglax09 binglax09 is offline
Senior Member
You can either just right it without the angle gear which does work but is not really recommended since the differential bearing is open to the elements.
The best bet is to just clean out the broken angle gear and place it back onto the tranny with the coupler unit to seal it. That will work without ANY issues!
Ive done both both of the above without issues along side just taking the angle gear out of AWDs that had bad VCs.
If you want to go more extreme then this and totally do away with the AWD system. You can drop the tranny out, and replace the differential and the bell housing with a FWD unit. OR just replace the differential with a FWD one and use the proper rotating seal to compensate for the size different from the bell housing to the axle.
PM me and I can talk to you further on the phone if you need help.
  #4
Old 03-04-2009, 02:16 PM
Junior Member
Thanks for the reply.
Would it really be that difficult to eliminate the angle gear assembly completely by simply removing the unit and replacing it with a right side shaft assembly from a FWD s70/v70. The bracket points that mount the axle assy look to be the same. The vehicle naturally splits 95/5 with the AWD system in place until it is needed as far as I found out. The only issue I could see is the input side of the axle properly mating to the trans. This would in theory make the car solely FWD just the same as a regular v70/s70?
I am somewhat unfamiliar with the mechanics of the XC trans vs. a regular FWD. I would leave the angle gear assy in there, but it is missing two chunks out of the case.
Again I apologize for the ignorance.
  #5
Old 03-04-2009, 07:15 PM
Senior Member
The FWD and AWD trannys are identical other then the differential and bell housing(for mounting).
The differential just has an extra spline on it so that it will mate to the BG with the coupler.
The case it made so that it seals with the coupler for the BG. So if you just install the passangers side axle it will be open to the elements. Which isnt bad for a few months or what not but it isnt a long term fix.
You can't fix this issue with a different axle, only ONE type of axle will fit into that side of the differential due to it's design.
I can post up s a few images if you need that to get a better idea.
  #6
Old 03-05-2009, 11:32 AM
Senior Member
Here is an album of 4 images dipicting the differential for the AWD and the bell housing. CLICK
The passangers axle fits into that center hole on of the spline. There is a seal that goes on there which I had removed. So what it comes down to is that you need a broken BG in order to completely seal that side of the tranny.
  #7
Old 03-05-2009, 12:40 PM
Junior Member
Thanks for the reply and the pics.
I have the old broken BG. The top of it's case is broken. The side that mounts to the trans is good.
So basically if I bought a FWD right side axle, and cut the end off of the BG that mates to the transmission, I could use the FWD axle and properly seal it from the elements?
You said there is one extra spline on the shaft itself. Would this mean breaking down the trans and replacing the diff with one from a FWD?
I basically am looking for a reasonable fix/mod that will allow for the car to operate properly without the AWD. Like I said it is a nice piece and besides this issue mechanically sound.
Thanks for all of your input. I have yet to remove the BG. I was waiting to find out if a reasonably priced used one was available, or an adequate modification was possible.
One last thing. Does the entire sub frame need to be removed to take out the BG, or can it be slid out some other way?
You guys rock on this forum. Off to drive my 12 MPG Suburban until this is fixed.
  #8
Old 06-24-2009, 02:59 PM
Chilled Man's Avatar
Chilled Man Chilled Man is offline
Senior Member
I have a used 99 Angle Gear sitting in the garage .....
and less then 2hrs away from you
__________________
01 V70T5-M56 01S60T5-M56 1999C70T5 1998 C70 T5-M56 1998V70R-M56 1998S70T5-M56
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
home | news | features | forums | product reviews | resources | photos | marketplace | contact
Interested in advertising on this site? Click here!
volvoXC.com is an independent publication and is not affiliated with or endorsed by Volvo or any of its subsidiaries.
PLEASE READ OUR TERMS OF SERVICE
© 2006 Servoweb Technologies Inc
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
