Results 1 to 5 of 5
    Aug 2007
    NJ
    Default Replacing Mini Bulb right below low beam H11 (drivers side)
    I cannot figure out how to get the mini bulb out of the headlight housing to change it. I can't tell if it rotates in like the H11 or pulls out or has some kind of release clip. I can get my hand in there and rotate it but that's it.
    Thanks!
    2017 Maserati Ghibli - Blu Emozione, Black Leather 17k miles
    2013 Subaru Outback - charcoal Grey, Eyesight Collision Avoidance 110k miles
    2007 XC70, Barents Blue, Charcoal Leather 200k miles
    2001 Honda Accord V6 SE - 82k miles - Steady reliable transport
    on the 2007 you squeeze the two tabs, then pull straight out. .......Takes a minimum of three hands with the headlamp on a bench and some very long needle nose pliers, long thin screwdrivers, hooks or whatever you can find to get the bulb socket out. Usually something plastic breaks during the process.
    Aug 2007
    NJ
    Ok...Thanks. Looks like I am not changing it!!
    Jul 2012
    Landenberg, PA
    I couldn't get mine out while the headlight assembly was still in the car. Hoonk has an accurate description of the process! I decided to polish the plastic on mine ('05), so I pulled both assemblies out and put all new bulbs in.
    2005 XC70 - 50/35 Tint, Yakima Rack
    Nov 2012
    Pacific NW
    Quote Originally Posted by perkinscl View Post
    +1 to this!
    Bumper cover really is a 10 minute job! The only way, in my opinion, to do anything with the headlamps.
    PDX-Vancouver, USA
    2005 XC70 140,000
