Results 1 to 4 of 4
    Jun 2003
    South Lake Tahoe, CA
    Default Seat memory adjustment not working
    The driver seat memory adjustment has quit working except for the mirrors. When I push the button on the outside of the seat nothing happens but the windows adjust to the preset setting for that button. However, the manual adjustments still work.
    I there a fuse for the memory function? Any other suggestions?
    Wait Griswold
    2003 XC70
    Feb 2011
    Windy Manitoba
    Have you tried resetting the seat memory? Adjust it to where you want then press M and the memory number button at the same time.
    Can you store new sideview mirror angles for drivers 1, 2 and 3? If so, then the "M" button is proved working. If not, then most likely the "M" button is shot.
    I had to replace the power-seat control switch assy. on a 2007 S60. Disconnect the battery during the entire swap procedure. Have ignition key in "II" position while reconncting 12V power.
    Jun 2003
    I was able to store the mirror angles so the M button is working. I also was able to store the seat positions and now the three positions all work. Maybe somehow resetting the three positions brought it back to life? A mystery, but all is well now.
    Thanks for your help.
    Wait Griswold
    2003 XC70
