Hey all,
First off, just wanted to say that this forum is a wealth of information and I appreciate everybody making it easier to take care of Volvo’s. It’s great to see.
After a long history of Honda’s and Subaru’s, I’ve decided to delve into the Volvo world. Always loved the look of Volvo wagons so I took the leap and purchased one. (After much research here of course.)
2004 Volvo XC70, 155k miles. History of this car looks fairly good. Here is what the Carfax showed before I purchased:
01/27/2004 - 7,788 - 7,500 mile service performed
08/24/2004 - 16,501 - 15,000 mile service performed
12/05/2006 - 31,022 - 30,000 mile service performed
Oil and filter changed, Maintenance reminder reset ,Wiper(s) replaced, Front brake pads replaced
07/14/2007 - 39,976 Brake fluid flushed/Changed, Air Filter replaced, Oil and filter changed
08/05/2008 – 48,692 Oil and filter changed,
06/05/2009 – 57,888 – Inner tie rod replaced, Oil/filter changed, fluids checked
11/11/2009 – 66,143 – Oil/filter changed, fluids checked
05/01/2010 – 71,459 – Oil/filter changed, light bulb replaced, fluids checked
09/10/2011 – 91,217 – Oil/filter changed
08/01/2012 – 99,884 – Oil/filter changed, front brake pads/rotors replaced
02/15/2013 – 104,436 – Oil/filter changed
05/01/2013 – 106,239 – Engine mount replaced, Timing belt replaced
11/16/2013 – 111,849 – Oil/filter changed, maintenance inspection
10/02/2015 – 122,286 – Oil/filter changed
08/01/2016 – 130,037 – Oil/filter changed, front brake pad/rotors replaced
12/27/2016 – 136,603 – Battery replaced, spark plugs replaced
01/16/2019 – 154,478 – Oil/filter changed
When I purchased this car last week I had it inspected by a great local Volvo place and had the following done per their recommendations:
- Rear cam seals replaced (leaking)
- New drive belt (cracked)
Here are my questions:
1. Gonna replace the PCV system myself with the help of my research. Looks fairly straightforward with the right tools etc
- Looking at this kit, should I just spend the extra money for the kit with the engine coolant hose assembly? (Adds an extra $189)
- If I have to drop the oil pan, is it a huge pain to do that? Could I replace the PCV myself and have my shop drop the pan and clean that part out for a reasonable cost?
2. Trans shifts like a dream. Doubt the fluid has ever been changed.
- Should I still go ahead with the Gibbons flush? Looking at this link it warns that messing with the fluid might make the trans more likely to knock things loose and mess it up. (Safety warning in the PDF instructions for that kit)
3. When should I think about replacing timing belt again. I have no idea if they replaced the tensioner/water pump etc when they did it at 106k miles.
I’m trying to extend the life of this car as much as I can. Anything else I should be looking to check/replace that I’m not thinking about?
