Results 1 to 10 of 15
Thread: '03 XC70 won't start
    Mar 2012
    Carbondale, CO
    Question '03 XC70 won't start
    My '03 xc70 with 118k miles won't start. I suspect it is a fuel line issue, perhaps the pump. We were headed home from a camping trip in the desert, stopped for a break, and could not restart the car. Ignition and starter crank, it seems to fire, but won't catch and run -- acting like a fuel line issue or a flood. I had all the 105k maintenance done months ago and doubt that the fuel filter is the problem. I had taken my car to Denver for maintenance where we found an excellent Volvo mechanic, but now live 3 hours from Denver and have been told many cautionary tales about the Volvo service in this valley being predatory and opportunistic. My concern is that this is a minor issue that a shop is going to use as a smokescreen to fleece me. Any thoughts, recommendations and advice are deeply appreciated.
    Mar 2005
    Pacific Northwest
    Check engine light on? If so, you have codes that can help with diagnostic. Unplug MAF and see if that changes anything.
    Not sure where else to start.
    Mar 2012
    Carbondale, CO
    No messages or error codes. Check engine light is not lit.
    Mar 2012
    Washington
    Default wont start
    Im nee to volvos. I had several cars that did the same. It turned out the timing belt stripped or broke.
    I dont know if volvos have the same system (that the valves and pistons wont touch) if the timing belt gives out. Its called interference engine when they do touch.
    You could disconnect the fuel line at the filter to see if you have fuel flow.
    Mar 2005
    Pacific Northwest
    An easy way to check the timing belt is to remove the top cam/t-belt cover held down by 2 clips and 2 torx bolts. You can see the timing belt riding over (or not over if broken) the cams gears after removal. Googled and found a pic
    http://www.flickr.com/photos/roryfla...8027/lightbox/
    BTW, these are interference engines.
    Mar 2012
    Carbondale, CO
    Timing belt was replaced recently along with the rest of the 105k maintenance checklist.
    Jul 2008
    Ottawa, Canada
    Check the fuel pressure - there is a valve under the cap on the fuel rail on the front of the motor. Release the pressure into a cup with the ignition off for a few minutes then turn the key to II and check if you have pressure again. That will tell you if the fuel pump works at all. The fuel sensor can be read through the OBDII live data with the appropriate reader.
    I log about 300 kPa fuel pressure (43.5 psi).
    MY05 XC70: +4C+DSTC +Premium Pkg +Zimmerman Coated+Ceramic +General UHP+Rims +IPD Solid Strut Conv. +IPD Poly Mounts +IPD HD TCV +IPD HDCoils
    Dec 2002
    TPE>BNE>DFW>AUS>TPE
    I would unplug the MAF and try to see if it starts too.
    2002 V70XC w/volvoXC.com stickers! MTE Stage 3+
    Quote Originally Posted by drnukeit View Post
    This is an interference engine...lose the belt and you'll bend valves...most high performance engines are interference engines...more valve travel/overlap for more power...
    2005 MB S600 (96K, Michelin AS3, M1 0W40)
    2002 V70-XC (233K, AltiMax RT43, Castrol Edge 0W40)
    Mar 2012
    Washington
    Default belt
    Thanks Astro. I will need to do my belt.
    On the 03 that wont start, how was the fuel pressure? Have you been able to look at the coils?
