Any one care to post their experiences with transmission additives?
I am doing another drain and fill tomorrow and I think I will add some Sea Foam Trans Tune to my gearbox. I have had good results with the Lucas Stop Slip/Tans Fix before in older Mercedes. I used it in two 1967's a 230 and 230S, I know they were a little different style trans but it smoothed them out. One had flaring and one had a harsh engagement, both of which sometimes occurs in my XC70. Also used in a '79 240D which had no issues and never developed any either.
I am thinking about the sea foam because the ipd website sells it and I assume if they are selling it they maybe have tested it or at least its compatible with the 3309 type trans fluid.
I have a bottle of the Lucas stuff but I am hesitant to put it in this car. I read on a site about oils that it had made some peoples cars (not specifically Volvo's) shudder.
My thinking is this stuff is too slick for the surfaces to lock up all the way. I am already having a little bit of not going into full lock up issue, but the slickness of it could help the other moving parts. (Just my theory from previous use).
Also on the lock going into full lock up thing... Sometimes it does sometimes it doesn't, about 85% of the time not. It seems to try and lock up and bounce back and forth between lock and unlock over and over. I also have another post on this from a few weeks ago and I think I have come to a better understanding of what it trying to do.
On its good days its a pleasure to drive, the pedal is very touch sensitive like it just floats along and is often switching down and up through gears smoothly. On the off days it shifts to fifth gear asap and doesn't want to downshift, I have to force it to unlock by nudging the gas so it will stop shuddering and as my speed levels out the rpm's drop low and I feel the Shuddering vibration, so step on the gas and repeat.
Driving me crazy, It feels like work to drive this car..
Car is a 2001 V70 XC, 134,000 miles.
