Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    Aug 2007
    NJ
    That is almost certainly what happens. The transmission seal around the transmission output shaft is likey bad where the mating collar between the bevel gear and tranny slide over the splines. I have my bevel gear out and there is not other lace it could be coming from. There is no fluid in a cavity behind that bolt. Me, until it gets really bad I would just keep checking the fluid level. You have to pull the bevel gear to change that seal and although it is not difficult it is time consuming.....if you do, change the axle seal on the transmission output shaft, and the sister seal around the collar on the bevel gear side....
    Feb 2011
    NZ
    I bought the seal and everything and posted here. But the leak stopped. It has been several months and nothing came back. I cannot understand. But am relieved.
    However, if it comes back I will have to review these pages.
