Help!
I have a new leak on my Wifes XC90. It appeared to be the sunroof drains but they were clear. Tracing it further, I found it is coming from the large white plastic box under the dash and behind the glovebox on the passenger side.
A link to the parts diagram is shown below. The plastic housing does have a drain through the floor, and it is clear both down through the body and up into the housing but the housing continues to leak.
http://www.partswebsite.com/autopart...40&catid=34585
So here's the question(s). How is the water getting into this part? Is this the fresh air intake and does it maybe come from the cowl area? Why would it not be flowing to the drain but rather seeming to leak from where the blower motor (part 18) mounts to the bottom of the casing (part 5)? Has anyone else gone through this one?
Edit: Perhaps if the cowl drain is clogged the water is finding a way in from the cowl area and running around this heater/air conditioner part before dripping on the floor? I can't see any water when looking through the glove box area at the cowl. I only see water down at the bottom of the motor/housing.
