Results 1 to 5 of 5
Thread: Cam seal(s) replacement advice
    Aug 2009
    Maine, Bath
    Default Cam seal(s) replacement advice
    Looking for advice in regards to replacing my front/gear-side cam seals as they're leaking. (And yes, I already replaced my PCV system).
    Here's what I think: I just need to line up TDC & note cam marks to marks on timing cover, (remove wheel, 30 mm socket to rotate crankshaft, take measurement between gears, etc... ad nauseum). Then using a hex key relieve pressure from Tbelt and slip off top gear and remove gear(s)... this is where I'm stuck... how do I remove the seal, or replace for that matter?
    Thanks,
    Colin
    Sep 2007
    Calgary, AB
    CVVT Cam pulleys on these cars are not for the inexperienced - just an FYI. There is a fairly complicated procedure involved in setting them back up when you're done. You'll also require the cam locking tool from Volvo.
    Aug 2009
    Maine, Bath
    Thanks, however I don't think I can use a cam lock tool as it covers the seal... or can I?
    Nebraska
    Default Cam locking tool
    It goes on the rear of the cams
    Aug 2009
    Maine, Bath
    Thanks for clearing that up Jonnie, I thought for sure the tool went gear-side.
    Anyway, I still have to figure out how to replace the seal... I may ask my Volvo dealership parts guy, he's seems pretty knowledgeable.
