Results 1 to 4 of 4
Thread: Engine oil drain plug torque
    Question Engine oil drain plug torque
    I understand the plug has to be tightened with care since the bottom of the engine is aluminium.
    It is not the first time I drain the engine oil, but this time, when removing the plug, it felt as if it
    wasn't very tight. So I payed extra attention when tightening the plug, new washer, torque key
    set at 35Nm per Volvo spec. And this felt if it was too little (so I added a bit of torque ).
    Am I the only one to have this impression? You know, once doubt sneakes in.....
    Willy
    Western Head, Nova Scotia
    Willy
    I do my strictly by feel and have never stripped a pan, had a plug fall out, or actually had a leak (assuming a new washer). These guys that strip the threads must be absolute gorillas as I probably put about 35Nm by just putting a bit of my Wheaties to it. I even had a plug in a new SAAB I bought once that took a 4 foot breaker bar to break loose and the thread was OK.
    '05 V70R (Magic Blue)-117K mi to-date
    '05 XC70 (Lava Sand)-268K kms to-date
    '98 V70-gone @390k kms
    '76 265-gas hog gone
    And other misc. Euro stuff
    Jan 2007
    Nova Scotia, Canada
    I torque mine to 32 lb/ft. The first change I did on that car, I over-torqued to about 47 lb/ft because it just didn't feel tight enough at the correct torque. I shat bricks for 6000 kms until it was time to do the next change. The drain bolt was fine and so were the threads in the pan.....no harm done.
    Dave.
    Nov 2002
    SE WI
    No problem by hand!
    I've taken the plug off after my indy guy changed oil and had to get a breaker bar to do it, so its very hard to really damage the plug threads or the pan threads.-Dick
    '11 XC70 Silver/Off Black-Hers
    '03 XC70 Silver/Charcoal-His
    '99 XC70 Silver/Charcoal -Granddaughter's
    '87 740GLE Junk Yard@287K miles
    2013 Porsche Boxster
    2017 Porsche C4S
