Results 1 to 9 of 9
Thread: Check Engine Light ON - Code PO442
    Rhode Island
    Default Check Engine Light ON - Code PO442
    My Check Engine light came on last week shortly after a fill up at the gas station. I checked the code using a generic scanner and it pulled code PO442. I have also randomly been getting a message on the instrument panel saying that the 'fuel filler door is open-loose".
    I ended up replacing the gas cap clearing the CE code and the message came back shortly after, but the CEL has not come back yet. I recently had a software upgrade for the Leak Detection software download for the ECM air pump and I'm not sure if the PO442 code is related to a bad air pump or maybe the charcoal canister is bad. Sometimes when I fill up the car the pump will auto shut off and then spill a ton of gas as though I overfilled the car (not sure why because I stop pumping when the pump shuts off).
    Here is a photo of what I see underneath the car looking up at the fuel door:
    Are the hoses with the arrows pointing to them supposed to not have anything connected to them?
    Ontario,Canada
    I have a 2003. If we are looking at the same thing I do have hoses coming from there.
    I'm looking up behind the rear wheel to the side of the gas tank. I see a bunch of hoses there. I see that tubular shaped thing with a hose coming out of where your arrow points.
    Jim
    Rhode Island
    Jim
    Could you supply a photo by any chance?
    Ontario,Canada
    When my wife gets home with the car I'll take a picture.
    Jim
    Jan 2008
    Arlington/Newport News, VA
    Those might just be breather tubes for the gas tanks, but don't quote me on that one.
    '05 XC70
    -Pioneer Avic F700bt headunit
    -12 inch Alpine Type R Sub
    -Flat Black Pegs
    -Custom Tinted Windows
    -Custom Mesh Grille
    -OBX Catback Exhaust
    -IPD Silicone Hoses
    Ontario,Canada
    [IMG][/IMG]
    Ontario,Canada
    [IMG][/IMG]
    Rhode Island
    That's what I thought otherwise the CEL would be on all the time right?
    Ontario,Canada
    So it is the same. Your picture is just further up..
    Quote Originally Posted by jdp6000 View Post
    [IMG][/IMG]
