Results 1 to 7 of 7
Thread: Oil Drain Plug Torque
    Mar 2006
    Maine
    Default Oil Drain Plug Torque
    I'm getting ready to do my first DIY oil change on my '04 XC70, and I can't find a torque specification for the oil drain plug. Is there an established number, and if so, what is it? Thanks, DC.
    Oct 2003
    Michigan, USA
    Quote Originally Posted by dcandmc View Post
    35 Nm / 26 lb ft
    StonGard Light Protection, Yokohama YK740 GTXs, Moog Sway Bar Links, ipd HD TCV, subframe & top brace poly bushing inserts,
    Feb 2003
    Dimock, PA
    And the Torque for the plastic oil filter housing is also 35Nm.
    03 XC70 OSD (traded-in 4/12)
    12 XC70 T6
    16 S60 T5 Drive-E (FWD)
    According to Vadis, the torque for the oil filter housing is 25Nm.
    Part number for the gasket of the drain plug is 977751
    Filter insert (new O-ring I think) is 1275810
    Willy
    May 2007
    Central PA
    You should change the oil plug gasket too.
    2003 XC70
    BFG Mud Terrains
    IPD Aluminum Skid plate
    Curt Hitch
    Yakima Basket W/ Spare Tire Mount
    Poly Upper and Lower Motor mounts
    IPD Gauge Rings
    ETC ...........
    Mar 2006
    Maine
    Quote Originally Posted by uscgc70 View Post
    Thanks, everyone. I've got a new crush washer, plus a new O ring for the filter housing. So, the drain plug torque is 35 nm / 26 ft lb, and the filter housing is 25 nm?
    Feb 2003
    Dimock, PA
    Willy,
    I was surprized to see your reference to 25 Nm for the filter housing because I had written down 35 Nm after checkling in VADIS. Turns out we are both correct. In the listing of torque setting for various components under the "General" segment under the "Engine" option the torque is listed as 35 Nm but under the specific instructions for doing an oil change it is listed as 25 Nm..... However, your figure is probably the one to use. The plastic housing on mine has the torque specified on it as 25 Nm...
    12 XC70 T6
