Page 1 of 8 12345678 LastLast
Results 1 to 10 of 74
Thread: Bulb failure...Position light???
    May 2007
    michigan
    Default Bulb failure...Position light???
    Any idea where the "position light" is? I looked in the manual and didn't see it anywhere....
    Thanks in advance,
    Mitch
    Mitchgat
    '03 Silver XC 58k
    Oct 2006
    Nashville, TN
    In the tail light housing. Number 3 in this image:
    2001 Volvo V70XC
    Venitian Red/Beige
    08/01 Build Date
    Jan 2007
    Oakville, Ontario, Canada
    Default Also in the front
    There are position lights (parking lights) in the front as well. The small filament in the turn signal bulb, I believe. So you'll have to replace the whole bulb.
    Harold.
    May 2007
    Central PA
    My car gives me this message about 3 times a year, and it's always the left rear. i just go back and give the lens a whack with my hand and it pops back on. no big deal, but kind of a barbaric fix
    2003 XC70
    BFG Mud Terrains
    IPD Aluminum Skid plate
    Curt Hitch
    Yakima Basket W/ Spare Tire Mount
    Poly Upper and Lower Motor mounts
    IPD Gauge Rings
    ETC ...........
    Nov 2004
    New Hampshire
    Quote Originally Posted by uscgc70 View Post
    Same here.
    May 2007
    michigan
    Default Hmmm...
    Mine just happens to be left rear.....I'll try it and report back.
    Mitch
    Mitchgat
    '03 Silver XC 58k
    Jun 2003
    South Lake Tahoe, CA
    My left rear is also not working. I will whack it today and see what that does. What is the function of these lights?
    Wait Griswold
    2003 XC70
    I think you can leave these lights on when leaving the car in a dark place,
    so that its "position" will be visible. Since the total power usage is quite low,
    it should be possible to leave the car for several hours with the position lights on.
    I don't know if this function interferes with DRL's, my car doesn't have DRL's, when I leave
    the car, I can put the light switch at twelve o clock to turn the position lights on.
    Some (European) cars have a feature that when the contact is turned off with
    the direction indicator handle in the left or right position, the corresponding position
    lights will stay on to mark the car. This enables the car to be better visible on the side
    closest to the road while using even less power.
    Willy
    Apr 2008
    Chicago (USA)
    Me too - just happened last week while on vacation trip ....
    (2002XC)
    Apr 2008
    Knoxville, TN, USA
    Post Position Light
    Before you go beating up your car's tail lights, check fuses 30 and 31 in the left side of the dash under the panel. I also just had this problem pop up and found 2 blown fuses. I think mine may have come from hooking up to a trailer with faulty wiring.
    Good Luck,
    Larry S.
