Originally Posted by
Willy
I think your problem could be related to the interior temperature sensing system. There is a small fan to blow inside air over
a temperature sensor. If this fan is blocked/clogged, the AC will not react normal.
The fan can be found behind 3 small slots in the center console, above the passenger temperature setting knob.
Try to see if is free, if not try to vacuum clean or air blow, not using too much brute force.
There are other possible causes of your problem but it may be best to check the simple things first.
Willy
I had the same symptoms as "dtlayman", went to the garage they changed what Willy mentioned and the problem was over , it takes only five minnutes to replace it.
Before....
1993 Opel Astra GSI 16V
1998 Volvo T4
2000 Volvo V40 2.0T
2005 Honda Accord 2.4 Executive
2004 VW Bora 1.9TDI
2007 Ford Focus TDCI
2001 Volvo V70XC
Now.....
2003 Volvo XC90 T6 AWD
2008 Mitsubishi Pajero 4x4 3.2DiD
